It is currently Tue Jun 24, 2025 2:52 am
PostPosted: Tue Apr 18, 2006 7:24 am
Hi
Wonder if I could canvas the opinion of the classical guys on a good thickness for classical sides, I am using EIR.
I have several books all of which are slightly different.
Many Thanks
Russell
PostPosted: Tue Apr 18, 2006 7:27 am
I always take EIRW sides down to .080"-.085" or 2.0mm-2.2mm. I've never had any problems bending the wood at this thickness, and I've also never had any cracks or problems at this thickness.
Cheers!
PostPosted: Tue Apr 18, 2006 7:31 am
Thanks John
Thats the same as I would use it at on my steel string, wasn't sure if classicals were suppose to be thinner or not on the sides.
PostPosted: Tue Apr 18, 2006 7:38 am
Last Name: Beaver
City: Lake Forest
.085 to .090 works for me before bending. After final sanding and all it usually comes out about .005 less.
Joe Beaver
Maker of Sawdust
PostPosted: Tue Apr 18, 2006 7:41 am
That's what I aim for too with my steel string guitars. I have read that some classical builders use sides much thinner than that; if I recall correctly Torres build guitars with sides as thin as 1.5 - 1 mm in some cases. True?
PostPosted: Tue Apr 18, 2006 7:45 am
First name: Josh
Last Name: French
City: Houston
Russel,
I thickness most of my sides to 1.8mm before bending, for a final thickness of around 1.6 after binding. Of course, I am the opposite of the current trends (4mm thick double sides), but I base most of my building on the old Spanish makers who often had sides thinner than even I.
A cursory glance at some measurements -
Several Torres guitars ranging from 1.0 to 1.7mm (thickest for Cypress, Maple)
Several Simplicio instruments coming in at 1.3 to 1.7 (thicker for maple, etc)
and
Manuel Ramirez and Santos Hernandez coming in at less than 1.5 in all instances noted.
Measurements coming from "Masterpieces of Guitar Making" by Stefano Grondona and Luca Waldner.
Instagram: @jfrenchluthier
PostPosted: Tue Apr 18, 2006 8:46 am
I take mine to 1.8mm
PostPosted: Tue Apr 18, 2006 9:47 am
Question for Joshua, Robbie, John, Arnt and anyone else who wants to lecture an old duffer:
How do you measure / what tool do you use to get that .1 of a mm? You know I'm not a metric guy, so you can quit laughing now.
Ok...now.
now?
SK
PostPosted: Tue Apr 18, 2006 9:52 am
First name: Josh
Last Name: French
City: Houston
Steve - a scraper and a caliper. A safe-t-planer gets it close.
PostPosted: Tue Apr 18, 2006 9:57 am
Joshua--I think the answer I was looking for was your "caliper".
I asked my question so poorly, that I should re-state:
it's the measuring of those pesky little mm's down to a decimal point that has me so impressed. And how one accomplished this.
You must have a metric caliper?
I've never seen one, and I should have poked around your shop a little more closely.
PostPosted: Tue Apr 18, 2006 10:03 am
Steve,
Yes, you got it. I have a digital caliper that measures to 100th of a mm and 1000th of an inch. I love that tool! It has a little button you press to switch between inches and mm's, and it's dead accurate. It's one of those tools you use all the time and wonder how you ever managed to get by without it. I find it very useful for other things like measuring veneer as I'm sanding strips down to make rosettes, purfling, bindings, etc. It seems that almost every classical plan I have gives all measurements in mm's.
Cheers!
JohnJohn Elshaw38825.795625
PostPosted: Tue Apr 18, 2006 10:08 am
Thanks John, I think if I had one of those gizmos I might switch to metric.
Or at least be able to talk to you guys more intelligently.
PostPosted: Tue Apr 18, 2006 10:30 am
First name: Josh
Last Name: French
City: Houston
Steve - I've got to encourage that. I know its an old debate, but think about how it can help ones understaning of the measurements.... when your point of reference is one and the deviation is only a tenth its simple. 1.9mm has got to be easier to understand than 75 one thousandths of an inch. When you have almost 2 of something, and your reference measurement (millimeter) is one its easy to understand. How does 75 one thouisandths relate to an inch in terms of a luthier's understanding? That seems more difficult than it needs to be.
What I mean is - its easier to measure to .1mm than .0748in. It is more accurate too. You'd need 25.4mm to make an inch. Its just easier to have a base measurement that isn't already a tenth of the desired thickness. You're starting at 1 instead of 1/25 basically (total estimation).
From LMI, IIRC. 1 represents one millimeter, 2 represents twomillimeters and so on. It makes it visually very simply. Love this caliper, I use it for everything (I even route my bindings with it!)
jfrench38825.8187384259
PostPosted: Tue Apr 18, 2006 10:34 am
First name: Josh
Last Name: French
City: Houston
In other words, if I were using an inch as my standard unit (1), it is 25.4 times larger than if I used a millimeter.
PostPosted: Tue Apr 18, 2006 10:47 am
just remember that a mm rounds out very nicely to .040". Its really .0397" but who cares. So anyway .1 mm is .004" or 4 thousands. 2mm sides are .080". 1.6mm sides are .064". It really is not to hard to get if, and only if, you use it often.
PostPosted: Tue Apr 18, 2006 12:50 pm
Oooh, a tag team effort!
Nice try guys. And, I know your approach is logical.
And Joshua, your arguments make perfect sense.
But, I guess all that's left to my foot-dragging is prejudice and long practice.
It did my heart good, though, when you answered the measurement question about the P/H width-- 3 inches, tapering to 2 1/2 inches. Good for you. A bilingual luthier!
Thanks guys, you just might make a convert yet.
Steve Steve Kinnaird38825.9108101852
PostPosted: Tue Apr 18, 2006 2:45 pm
I go 1.6mm - 1.8mm
PostPosted: Wed Apr 19, 2006 4:18 am
Thanks All
Much appreciatted.
PostPosted: Wed Apr 19, 2006 9:53 pm
Heh, Russell, nice burst on your avatar
PostPosted: Thu Apr 20, 2006 6:31 am
[QUOTE=jfrench]How does 75 one thouisandths relate to an inch in terms of a luthier's understanding?[/QUOTE]
Easy, it's 3/4 of one tenth of an inch!
